05-02-2019
11:14 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-02-2019
11:14 AM
Hello @Anonymous,
Thank you for posting. ![]()
When inserting objects like blocks from a drawing using different units of measure, the host file should automatically make this adjustment to the objects changing the units to match the host drawing.
- To check that the drawing units for the receiving/host drawing are correct, use the -DWGUNITS command and follow the prompts.
- There are three system variables (INSUNITS, INSUNITSDEFSOURCE, and INSUNITSDEFTARGET) that control the insertion scale for blocks, xrefs, and raster images. Inserted objects should be automatically scaled to the units of the host file. Files that are created with different units will be converted to the units specified in INSUNITS if your files have been configured correctly. For example, a file drawn in millimeters will be automatically scaled to meters when inserted into a drawing that is setup for meters. Check that INSUNITS is set accurately. If the units are not specified correctly in all involved files, automatic scaling will not work as anticipated.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
