05-02-2019
10:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-02-2019
10:42 AM
>>>...Other people with the exact same spec laptop are not having this issue....<<<
Something, or something else, is totally different for you from all the others. If it was just AutoCAD it would not manifest itself in blank files or in files someone else in your office uses that they have no issues with using "...the exact same spec laptop...".
You will need to engage your I.T. folks for a solution: one quick test would be with an all new log-in for Windows to see if the problem persists or its gone, another not so easy test would be to use an AutoCAD ARG Profile from another PC and not yours to see if the problem goes away, or finally your laptop needs to be re-imaged to match all the others in the office that work just fine.
or some combination of the first and last tip.
Good luck.
Good luck.
