natasha.l
en respuesta a: Anonymous
Hello @Anonymous,
There is no switch on/off, but there is a dialog box where you select all links & at once to have your links update manually you can follow these steps:
  1. Click Edit menu > OLE Links.
  2. In the Links dialog box, select the links you want to update.
  3. Click Update Now.
If you want to select the links from the drawing area rather than from a list in the Links dialog box, select the OLE objects first.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
