05-02-2019
06:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-02-2019
06:26 AM
You do know you can change that in the XREF command palette through a pulldown after you select he XREF(s), right?
-XREF command (the commandline version) can also do it for you if you use * when asked to select the XREF(s).
Try it and see: detaching and reattaching is an ancient irrelevant method.
