250 Vistas, 4 Respuestas
05-01-2019
10:06 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-01-2019
10:06 PM
Script
Is it possiableto change already attach external references from "Attach" to "overlay" by a script?
I do not see that option!
Now I have deattach and attach agin chosing "overlay"!
05-02-2019
06:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-02-2019
06:26 AM
You do know you can change that in the XREF command palette through a pulldown after you select he XREF(s), right?
-XREF command (the commandline version) can also do it for you if you use * when asked to select the XREF(s).
Try it and see: detaching and reattaching is an ancient irrelevant method.
05-02-2019
11:51 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-02-2019
11:51 AM
The issue is to change from attach to overlay by script.
I can not see the option you mentioned.
05-03-2019
05:47 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-03-2019
05:47 AM
No script, you need more, ask in the LISP forum for a customized solution https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
