- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
OLE Links - Manual
We are a small office and utilize Excel, linked into AutoCad for our schedules. We have played with Table Links and don't want to pursue that. The Excel links work great, but if one person is in Excel and another person tries to open a DWG file that has many Excel tables linked, it gives an annoying repeating warning about Read Only and takes forever to open the file. That said, I found that if we switch the update all the OLEs from Automatic to Manual with OLELINKS, it works very cleanly, and then we can manually update only when necessary. Unfortunately, that puts an extra step of remembering to switch all the OLEs to Manual which seems to be the default. Is there any hidden Toggle/Switch that I could set so the Default becomes to Link Manual instead of Auto? Here is the link to the AutoDesk description:
Brian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello @Anonymous,
There is no switch on/off, but there is a dialog box where you select all links & at once to have your links update manually you can follow these steps:
- Click Edit menu > OLE Links.
- In the Links dialog box, select the links you want to update.
- Click Update Now.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
