en respuesta a: Kent1Cooper
Thanks, guys. I guess I never associated the blocks available with INSERT as the ones used in the drawing.
I'll have to look up the difference between Undo and Oops.
If I understand correctly, I can still use INSERT to recover a block deleted months ago so long as I haven't purged it, yes?
Also, is there a way to have the file names of the Auto-saved backups all unique? Perhaps with either a numeric suffix or timestamp or something like that? (ha, if the answer has to do with a lisp routine, then it won't help those of us running LT...) Thanks in advance
I'll consider the original question solved. :cara_con_una_leve_sonrisa:
