04-30-2019
09:18 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-30-2019
09:18 AM
A couple more items to add to those already provided by the other individuals that responded to you:
- You can rename a BAK to a DWG to restore the prior version of a file before the latest save. Of course as you mentioned days or weeks ago, this is not going to solve the problem -- however it is useful if you 'catch' the issue just after it happened and just after up-saving a file.
- Check with you local IT - most companies employ some backup functionality on their servers so you may be able to request an older version of the file from your company's backup protocols, of course dependent if your company has this type of system in place.
Good Luck!!!
Chad Franklin
