- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
Occasionally I find I have deleted a block days or weeks ago that I still need. If I haven't purged the drawing, it should still be recoverable, yes? ....
You can INSERT another one, but you can't recover the deleted Insertion of it, except under some specific circumstances [the first two of which will not be applicable if you're talking days or weeks ago]:
1) If you notice immediately, of course, you can use U to undo the deletion/erasure of it;
2) If you're still in the same editing session, and you haven't Erased anything else or removed anything else with a BLOCK or WBLOCK command since [even if you have done other things that you don't want to lose with U commands], you can use OOPS to bring it back.
3) If you happen to have saved a version of the drawing before that was removed, you can open that, copy the Insertion you want to restore from it, and paste it into the current drawing, which will at least preserve its Layer and scale factors and rotation, etc., so you don't need to know what those were, as you would to just Insert a new one.
