Alfred.NESWADBA
en respuesta a: Anonymous
>> When i want to open  JC ,the error appear.
So that happens only with one specific drawing?
Start AutoCAD (just an empty drawing), run command _RECOVERALL and select this drawing and see if there are errors (which hopefully get cleaned).
As you are using Windows 10 make sure you have installed AutoCAD 2016 SP1 >>>click<<< as this seems to have some issues solved that might happen with Windows 10.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
