>> If you open the second drawing from Acad, no problem. If you try
>> to open from Moodle or Windows Explorer, Flash drive, etc. it crashes
For opening from Windows Explorer ... do you mean a double click on a dwg-file or drag and drop a dwg-file from Windows Explorer into AutoCAD?
Other question: "Windows Explorer" is a software, "Flash drive" is a hardware, I understand that you can use a software to do something with a file, but "Flash drive" is just a storage space, that does not have any functionality to open a dwg-file. (and I don't know what Moodle now can have to do with opening dwg-files).
So I would like to ask, is it the storage location that makes the difference or is it the software you use to open the file (and how do you then open the file)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
