304 Vistas, 6 Respuestas
Imperial annotative Help requested
Drawing already setup requested
Would someone have an imperial .dwg file they don't mind 'sharing'.  I guess I've been away from ACAD for too long, as I can't seem to get the setup of the floor plan. The other plans and drawings will follow after the first sheet has been properly setup, once   the proper annotative text and dims are all setup.  I am working on a small renovation project approx 5000sf using a 22x34 titleblock (which I have)
Yes I am requesting to do this the 'easy' way as I simply cannot figure this out.  I don;t want to draw everything in model space title block etc and print from the same, nor do I want to annotate in Pspace.
If you have something I can use that would be great. If not thanks for reading.
