RobertMyb
845 Vistas, 8 Respuestas
Matching layout page number with sheet number
Hi.
I have a page number in the corner of each of my layouts, is it possible to somehow make these page numbers automatically match with my sheet numbers?
imadHabash
en respuesta a: RobertMyb
you can create a text field added to your text . >> Click <<    >> Click 1 <<
Imad Habash
RobertMyb
en respuesta a: imadHabash
Hi Imad
Thanks for the reply. I have read this solution on several forums, however, I have quite a lot of layouts currently. Is there any way to avoid having to change each layout page number individually?
imadHabash
Sorry ... i doubt that it could be !!
Imad Habash
RobertMyb
Okay, thanks anyway.
maratovich
Why did you mark as a decision something that did not help you?
Attach an example of your files.
And specify what exactly needs to be changed.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
RobertMyb
en respuesta a: maratovich
I want the 'X' ,at the bottom right of the page, to match the prefix(sheet number) in the layout name(bottom left of screen)I want the 'X' ,at the bottom right of the page, to match the prefix(sheet number) in the layout name(bottom left of screen)
Hi
See attached screenshot and caption. I have several pages like this. Will I have to change them all individually or is there any quicker way of doing this?
maratovich
You can do this:
Run the program.
Open all your files.
The program automatically detects your title blocks.
You specify how to do the numbering.
The program automatically enters the numbers in all drawings.
But for this you need a real example of your dwg file.
Title units are different, numbers can be created in different ways. Need a check.
www.kdmsoft.net
RobDraw
Because it is the solution to the question as asked.
Now, they need a way to add the field to multiple files programmatically.
What's the problem?
Rob
