- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
new (relatively) dimension tool
i just recently learned about a new dimension mode however i cannot find it anywhere in my 2019 AutoCAD mechanical version. is it not available in mechanical? if it is where can i find it and add it to the dimension ribbon?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
make sure that you have an active ribbon up there at your CAD screen like the one in the image below , and you can get it by RIBBON command , from Annotate tab . also you can type _DIM command in the command line to get it . when you open Annotate tab some times Tabs and Panels are NOT there ... but you can get them by right click ( yellow star in the image ) and check them .
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That is a new feature available in 2020.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Imad,
Thanks for the _dim command line action and it does work if I type it in. I do have the ribbon and annotate panel but unfortunately i don't have this particular icon shown. i'm starting to think that this might only be available in Vanilla AutoCAD and not Mechanical (it looks like you're running standard and not Mechanical). If you know how i can add this to the ribbon it would be greatly appreciated. our users tend to use the ribbon (or menu's) rather than typing in the command line.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In that case I would ask in the forum for AutoCAD Mechanical >>>there<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
from Autodesk Help ( AutoCAD Mechanical provides a single command, AMPOWERDIM, to create all types of dimensions. )
Imad Habash
