j.palmeL29YX
en respuesta a: Anonymous
@Anonymous wrote:
If you could explain in steps that would be helpful
Video
First you need a closed polyline in the XY-Plane. Neither Pedit->Join nor the Join command work without problems. (I did not yet analyse what causes the problems). Therefore I "misused" the Hatch command to create this boundary.
Then you can go two ways:
- Create an extruded Surface and use the slice command or
- create an extruded Solid and use the intersect command.
Both ways are possible, the result should be the same.
Jürgen Palme
