j.palmeL29YX
en respuesta a: j.palmeL29YX
Do you need something like in the attached dwg?
It's not yet perfect (because of some inaccuaracies in your drawing) but if this is your goal I can show you tomorrow how you can do it.
Today in short words:
- Extrude the contour in the current XY-plane to a solid. (this is at the moment not accurate possible)
- then you can use the Intersect command to get the shown result.
Maybe you can build the model with this hints alone.
Jürgen Palme
