j.palmeL29YX
en respuesta a: Anonymous
I see you have a mix of solid and surfaces. (in the pic I moved the solid away).
I'm not sure what you want to do.
Can you show please in a sketched pic:
- where you want to cut (draw a cutline)
- what do you want to cut (the solid or the face(s)
- what do you want to delete
- and the "where there should be no extrude" I didn't understand at all.
Can you clarify please?
(a vague idea:
- use the union command to union all surfaces to one surface
- then use the slice command to to cut something.
Currently this doesn't work, but before I search what causes the failure I must understand what you want to do / to get)
Jürgen Palme
