329 Vistas, 6 Respuestas
Trim out open areas from a double cut operation
I have an operation where I double cut a part. Once cut you should be able to see through the part where the contour edges are. I tried to use trim surface and I can not figure out how to delete the areas where there should be no extrude. Please help
j.palmeL29YX
en respuesta a: Anonymous
I see you have a mix of solid and surfaces. (in the pic I moved the solid away).
I'm not sure what you want to do.
Can you show please in a sketched pic:
- where you want to cut (draw a cutline)
- what do you want to cut (the solid or the face(s)
- what do you want to delete
- and the "where there should be no extrude" I didn't understand at all.
Can you clarify please?
(a vague idea:
- use the union command to union all surfaces to one surface
- then use the slice command to to cut something.
Currently this doesn't work, but before I search what causes the failure I must understand what you want to do / to get)
Jürgen Palme
j.palmeL29YX
en respuesta a: j.palmeL29YX
Do you need something like in the attached dwg?
It's not yet perfect (because of some inaccuaracies in your drawing) but if this is your goal I can show you tomorrow how you can do it.
Today in short words:
- Extrude the contour in the current XY-plane to a solid. (this is at the moment not accurate possible)
- then you can use the Intersect command to get the shown result.
Maybe you can build the model with this hints alone.
Jürgen Palme
This is perfect and if you can please explain in more detail tomorrow, so what I can understand how to accomplish this in the future as well as make my drawings more accurate.
j.palmeL29YX
here a more accurate solution.
HTH
Jürgen Palme
How did you do the second drawing? If you could explain in steps that would be helpful
j.palmeL29YX
Video
First you need a closed polyline in the XY-Plane. Neither Pedit->Join nor the Join command work without problems. (I did not yet analyse what causes the problems). Therefore I "misused" the Hatch command to create this boundary.
Then you can go two ways:
- Create an extruded Surface and use the slice command or
- create an extruded Solid and use the intersect command.
Both ways are possible, the result should be the same.
Jürgen Palme
