04-21-2019
11:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-21-2019
11:34 AM
@Anonymous hi,
Attached cpat.lsp file to do what you want. plus cpat1.dwg block pattern to replace the circles.
save these files in your lisp library folder and load the lisp.
key in cpat on the command line and you will get this prompt:
Specify pattern to insert [cpat1/cpat2/cpat3] <1>:
you reply with 1 or 2 or 3 but at this moment there is only one block pattern (cpat1) with the pattern you want but as you can understand you can add more patterns. if you do? the new patterns must be build base on cpat1 which means it must be inscribed circle with R=1.0
next prompt
Select objects: <only circles will be selected>
enjoy
moshe
