433 Vistas, 7 Respuestas
Drawing Name
Why is it when I save a drawing called " Gable Cladding " and then do some work on it and save it again that it saves another drawing called " Gable Cladding 1 " and so on ?
Is there a setting that need changed ?
imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoCAD Forum,
it's weird !! tell us please what version of AutoCAD occur that ? and please confirm that if it's happened with every drawing even the new ones ?
Imad Habash
en respuesta a: imadHabash
Autocad lt 2019
Yes happens all the time
imadHabash
is there any lisp or plugin installed ? if Yes ... you may need to check that .
Imad Habash
ennujozlagam
hello, it could be accidentally use saveas instead of save...just saying..thanks
Alfred.NESWADBA
I guess you do not have enough permissions in the folder where the file is saved to.
Try the same on a new local folder, if that works well then ask your admin about permissions.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
BrianBenton
Do you or anyone else also have the file opened at the same time?
How are you saving the file? Go step by step.
Is it happening in a specific file or any file you open and save?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
pendean
WindowsOS or MacOS?
