- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I used to be able to hover over a nearby point, wait until it popped up "endpoint" or something similar and then move over to place another point that is aligned with this first point, through either polar tracking or ortho. As soon as the hovered point popped up "endpoint" I knew I was locked in. The "endpoint" no longer pops up and I can't do this any longer. Did I turn some setting off by accident or something? Thanks for the help.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Check the object you are snapping to. Is it an old-fashioned "2D Polyline"? (check the Properties).
If so, use the CONVERTPOLY command and convert it to a "new" style polyline
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I used to be able to do it with anything. A line, a polyline, a 3D wall from ACAD Architecture, didn't matter. It no longer works with anything.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Did you [accidentally, perhaps] turn off Osnap Tracking and/or running Object Snap? The F11 and F3 keys toggle those, or you can pick on their icons in the status bar -- make sure both these icons are turned on/enabled:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
