Alfred.NESWADBA
en respuesta a: Anonymous
>> did'nt get any replies or Soln's
Because there does not exist any solution (without catching the commands that do stretching)?
An entity in AutoCAD does not know if it was stretched or not, so you can't select them.
Even the event won't help if you get a drawing from anyone else, a line does not know it's history, does not know, how it was created or modified, so also not, if it was stretched or not.
As I wrote, you might catch the events (e.g. object modified, command started, command ended) so you get the entities handled by the activate command while the user is working. But when an object was stretched at any previous command you can't get them into a selection.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
