04-11-2019
02:59 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-11-2019
02:59 PM
Hello @BKELLEY70,
Thanks for posting.
This is likely due to the fact that they are out of view in "Top" view, because as you mentioned they are vertical. The edges of all 3D solids, surfaces, and meshes are projected in that line-of-sight & set view.
You can try to make these adjustments:
- The Flatshoot command creates a 2D representation of 3D objects based on the current view so try a different one from the 3d Modeling > command VisualStyles drop down
- Change the color for the vertical members to make them easier to see
- Make sure these members do not have any Transparency applied
- Edit the block that was created from Flatshot to make additional changes adding these vertical member manually
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
