395 Vistas, 2 Respuestas
Dimension Label and Text Sizing Issue
My dimension text and arrow size is different between model space and paper space. Originally, I create dimension labels on paper space through the model view and everything has worked. (My scale is set up to 1"-40' in model space and 1"-1' in paper space. I have all my text on an annotative scale.) Though when I am try to create the dimension labels in model space, the text size, the arrow size, and the whole entire dimension label is blown up to a much greater size than what is should be, but the exact same dimension label in paper space is at the correct size and not blown up. It is weird because my multileaders and mtext work just fine going from model space to paper space, just not my dimensions.
