pendean
en respuesta a: Anonymous
LINE objects do not rescale when copied between files set to mm or m or inch or any other unit size: your line comes in at the same 1000 units it is drawn at.
The tip/ability you are trying to use applies only to blocks and XREFs as well as a few key items only.
Could that be your actual problem, you are wanting something to happen to objects the program does not address?
