Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
.... when type "aecdwgsetup" in command, it show up unknown command.. it's that other way to permanently remove style override?
That's probably a specialty command in the old AEC overlay program [I think the "aec" part stands for Architecture/Engineering/Construction].  In "vanilla" AutoCAD, no commands defined specially in the overlay programs will be present.
See the beginning of Message 2 to clear overrides.  Or do you mean something else by "permanently remove style override?"  Do you want to remove it from Dimension objects already drawn?  You can use DIMOVERRIDE and give them the Style's native properties.  If you mean you want to make a certain override impossible to use, I don't know of a way to do that.
Kent Cooper, AIA
