04-11-2019
06:07 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-11-2019
06:07 AM
>> If I set the insert units in options to millimeters for source and inches
>> for target, or unitless for both it doesn't make a difference.
In case your 2 drawings, the one you copy from, and the other you paste to, does have units set, then both variables INSUNITSDEFSOURCE as well as INSUNITSDEFTARGET are irrelevant.
>> Starting from a blank drawing yields the same results.
In that case please:
- create a new drawing, draw a line with 1000 length, create a second drawing and use copy & paste to copy the previously created line into, save both dwg-files and upload them here
- start command _ABOUT and show us a screenshot from that dialog
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
