14921 Vistas, 13 Respuestas
Copy/Paste scale problem between drawings
I feel like there are several posts similar to this already, and I've searched and tried the solutions on those to no avail.
I'm using AutoCAD 2016, and when I copy objects or blocks from one drawing to another, even if the units are specified on each drawing, the scale is usually ignored. The source is typically (mm), and the target (in).
The prevalent solution seems to be -dwgunits, but with scale objects on insert and match insunits both set to "No" on both drawings, doesn't seem to impact anything. I tried various other permutations of settings for it.
I've tried setting both to unitless.
I've set insunitsdeftarget and insunitsdefsource as appropriate, and as unitless.
I remember being able to do it in the past, but when I asked my co-workers, they have the same issue and are just manually scaling things... I'm at a bit of a loss, and don't know what I'm missing.
