Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
....even if you selected a point out in space, the line would snap to the nearest node/endpoint/etc?
Only if some Osnappable location is within the Osnap target area.  The size of that is in the APERTURE System Variable.  If you don't see a dotted-square "target" when a point is being asked for, change the APBOX System Variable to 1 to make it visible.  Set that to a much larger value than the default of 10, and you'll "catch" Osnappable locations from farther  out in space, but still only within the range of the Aperture value, and the largest value you can give it is 50 [not "infinite"].  Beyond that, it will always use the cursor location itself.  [After all, what if there's nothing drawn yet?  What should it do then, in your requested scenario?]
Kent Cooper, AIA
