en respuesta a: Anonymous
Most of the projects I work on are also single file, multiple layouts. Utilising SSM just streamlines the process of having to manage title blocks, sheet numbers, revisions, publishing and more. I'd suggest you look further into it. There are a lot of good tutorials on YouTube.
Saying that, using SSM to publish PDFs is extremely easy. As easy as, simply setting up the way you want the drawings to be plotted to DWG to PDF plotter, sheet size, etc., as you normally would, just shift or control clicking the sheets to want to plot (or the whole project), and selecting publish to PDF. It's that simple.
