04-04-2019
02:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-04-2019
02:35 AM
>> I want to find the Stretched Entities
>> the Stretch will be done by User
What type of entities are your referring to?
Default AutoCAD geometry like line, polyline, arc, ... does not have a property called "stretched", so if you stretch a line from 100 length to 120 length this item does not know that you used "_STRETCH" to make it longer.
If you are using other objects, then please let us know which ones.
Just as idea: block-insertions have scale-factors, if you use these scale-factors instead of stretching you are able to later find all block-insertions with a scale-factor <> 1,1,1
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
