en respuesta a: Anonymous
If you want a laptop that will run AutoCAD nicely, you'd want to spend around $1000 for it, but honestly, if she will not be working on large project and it's just for learning AutoCAD, both of those laptops will suffice. AutoCAD isn't very demanding. I was previously working on a very old PC for almost 5 years before I decided to upgrade it to something more modern. The only specs I would suggest as a minimum is 4 cores, try to go with something that will go at least 3.5GHz boost speed (more the better), 8GB of RAM and an SSD. Graphics cards are not relevant for AutoCAD.
