neaton
en respuesta a: Anonymous
Set the PUBLISHCOLLATE system variable to 1. In the Publish dialog box set Publish to: PDF and Publish Options... to Multi-sheet file (should be pre-set when publishcollate =1). PUBLISHCOLLATE needs to be set on each computer that will use Publish to print to PDF.
Nancy
@Anonymous wrote:
I know that there are other ways to plot multiple layouts to PDF, but we use Teamcenter to control our drawings. Teamcenter has a built in option to create an auxiliary file (in this case a PDF). It takes its instructions from whatever settings you choose when plotting with DWG to PDF. You choose your settings, hit Apply to Layout, hit cancel, and upload.
There is a work around of creating your own PDF and dropping it in Teamcenter, but this can get out of hand.
If anyone can point me in any potential direction to make this a possibility , I would be forever grateful.
