03-26-2019
11:18 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-26-2019
11:18 PM
Search for MRS_SADV04.shx on 'the one' pc,
copy this file to the similar folder on the other both pc
and if this folder isn't a support folder, add this folder as support folder -
i am sure it is added at the one pc.
(Options/Files/ first node - Searchpath for supportfiles..)
You have to learn how to set up your program, how to backup setting&templates and so on,
i can not explain it in few minutes, sorry. For now: Make sure this file is also on a safe place
outside the program and profile folders!
Note: You have to send this file to every recipient of your DWG files (with these linetypes),
it should work work by using command: ETRANSMIT with incl. the FONT option.
Sebastian
