- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
LINETYPE
Has anyone come across the issue where a certain linetype won't display as intended and instead shows up as a continuous line?
We have 3 AutoCAD licences and everything works fine for one computer, but then on the other two it's not displaying correctly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
have you try to switch off hardware acceleration and see if helps. install latest updates from autodesk. thanks
have you change LTSCALE value.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Tried all that, however still not working.
I think it might have something to do with where it's looking for the .shx file, however I can't find where in AutoCAD it is that I need to direct to my C drive
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hello, is it possible you can share your file so we can check. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Very easy way: Upload dwg with one circle in model tab and one layout with one viewport.
As you say, this sample should works as expected at one of three PC.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please find attached.
The model is TOPO BANK TOP.
When I open the drawing I only get a continuous line, when it's meant to look like the .jpg that I've also attached.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hello, just go to your layer and change the linetype. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Search for MRS_SADV04.shx on 'the one' pc,
copy this file to the similar folder on the other both pc
and if this folder isn't a support folder, add this folder as support folder -
i am sure it is added at the one pc.
(Options/Files/ first node - Searchpath for supportfiles..)
You have to learn how to set up your program, how to backup setting&templates and so on,
i can not explain it in few minutes, sorry. For now: Make sure this file is also on a safe place
outside the program and profile folders!
Note: You have to send this file to every recipient of your DWG files (with these linetypes),
it should work work by using command: ETRANSMIT with incl. the FONT option.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I can do that, but the whole point of that linetype is that it represents top of bank. Using another linetype will give the impression that line is something else
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
hello, you can try this go to other computer and search for acadlin.iso, copy to your computer, load in your linetype and see if helps. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Check your annotative scale and line type scale... it's usually one or both of these things.
