- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Layout measure different for lenght and area (AutoCAD 2016)
I'm using AutoCAD 2016. I have a problem with measuring in Layout. When I use "Measure" tool for distance, it is shown 40 (as mm on paper) and after measuring it' 2000 (real distance in mm). When I use "Measure" tool for area, it always measures area on paper. In previous AutoCAD I used area measurement in same case and in worked perfectly - real area in mm was shown. How can I change measuring the real vs. paper distance?
Drawing in model is in scale 1:1, then layout in 1:50.
Drawing units are everywhere set to mm.
Page setup is in mm.
-DWGUNITS <3> (mm)
DIMASSOC <2> (0,1 with no change)
Thanks for response.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I noticed your answer just now. The dwg is attached.
Thank you very much for your time.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
How do you solved the problem ?? I have the same situation and I cannot measure the distance in the layout.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I had this problem just in one file. I made a new file, copy-paste everything from one to another and the problem dissapeared. I assume, that the first file was somehow damaged. New one works just fine.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the area in the table is correct in square meters. how do the table get set up/ generated? division by 1,000,000?
