ChicagoLooper
en respuesta a: Anonymous
Constantly 'changing' the o-snap settings is not considered a Best Practice.
While in a command, e.g. Line command, you can press Control+Right Click to bring up a shortcut menu and from there you may select an o-snap. Yes, you'll have to use a extra finger, but so what, the finger has many uses and is said to give you more power than a regular guy. Use the finger and be irregular.
While in the middle of a command, control+right click to get  o-snap shortcut menu.While in the middle of a command, control+right click to get o-snap shortcut menu.
Chicagolooper
