03-22-2019
01:51 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-22-2019
01:51 AM
Greetings, I'm using AutoCAD mechanical 2019 to set out Pipework using 3D blocks from our own library, these insert fine (use them all the time) but on larger models I'm having problems when I move the blocks - some become corrupted visually - wireframe/realstic view of block in different places "ghost image" see attached. The only way I've found to cure it is to explode the block which then becomes a mess of faces. Is there any way of stopping this happening?
¡Resuelto! Ir a solución.
