- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD page setup manager issue
I am trying to print using AutoCAD page setup manager. Everytime I close the AutoCAD i have to setup another page setup for giving prints. How can I save the particular page setup as default such that I dont have to setup again and again.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you start _PAGESETUP ... you can't print from that command. What command exactly do you use to print?
Are you speaking about the same dwg-file? Because creating a pagesetup is only saved in that dwg-file you have created it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you create a named page set-up it can be imported into existing files.
If you store the page set-up in your template file, it will be available on future files created from that template.
I usually keep a file handy that has most of the page set-ups that I use for easy importing.
Rob
