- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
This would be the perfect time to learn about creating named views while in model space, and then when in paper space insert that view. In model space, using the Ribbon, go to the View tab, Named Views panel, use the New View command there. In paper space, using the Ribbon, go to the Layout tab, Layout Viewports panel, use the Insert View command to place. Scale can be changed during insertion or after the fact.
This doesn't mean you should have objects a long ways away from your main model, just a way to ensure you get what you are expecting.
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
