408 Vistas, 3 Respuestas
AutoCAD 2019 blank model space
I've recently downloaded the student version of AutoCAD 2019. It installs fine, however when I open it up the model space is blank. It won't show any grid lines or the cursor in the model space or layout tabs, it just shows a blank screen, but the cursor still appears and I can still use the toolbar.
Any help on what's causing this would be great.
Kirsty
S.Faris
en respuesta a: Anonymous
Turn off Hardware Acceleration : How to enable or disable hardware acceleration in AutoCAD
SALMANUL FARIS
en respuesta a: S.Faris
This has worked - thank you!!
Alfred.NESWADBA
if turning off hardware acceleration helps to get something solved you might look to update (or downgrade) your graphic card driver to get the hw-acc back working without issues.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
