en respuesta a:
01:16 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-15-2019
01:16 PM
I don't have Revit, so I can't test how things look there, but by selecting dimensions individually (or any quantity at once) I am able to change lineweights in the properties manager, and see them change on-screen with lwdisplay set to ON. They change in a plot, both to pdf and paper too....Changing them in the dimstyle formatter changes all dimensions using the style I change there. Using (plain vanilla) AutoCAD 2019.1.2. After you make the change(s) a regen is required to see the changes happen. If this doesn't work, can you post a file with a dimension that won't change, along with what you want the lineweights to be?
