S.Faris
en respuesta a: Anonymous
if Lineweight is the issue, 0.00mm to 0.25mm will not show any difference on Screen(see below pic). But it will be visible in the print out(try printing to a PDF).I believe the lineweight data provided in Autocad will be transferred into Revit no matter what. So try making a a PDF and check the Lineweights in those rather than in the display.
Check this : Controlling line weight of imported files
SALMANUL FARIS
