pendean
en respuesta a: Anonymous
if you use AutoCADMEP, are you not using the PROJECT NAVIGATOR to set up all the various DWG files and titleblocks (and fields for unique sheet information) and so much more of that automation that is already built into your variant of AutoCAD?
Here is an overview of how to use your MEP software fully for the task you want https://www.cadlinecommunity.co.uk/hc/en-us/article_attachments/200578992/Whitepaper_Creating_Constr...
with more here http://paulaubin.com/_downloads/2010_AU/Book_Samples/AutoCAD_MEP/AutoCAD_MEP_Ch03.pdf
BTW the dedicated AutoCAdMEP forum is over here for all of your follow up questions and queries https://forums.autodesk.com/t5/autocad-mep/ct-p/2036
