S.Faris
en respuesta a: Anonymous
I would suggest you to start a new drawing, in that file create every CAD standard that you need in common for every newly created file. For example :
Create the Layers
Load the Linetypes
Do the Pagesetup
Create the layout sheet title block
Dimension style
Text style
Then Save-as the file as .dwt in the default template folder
Next time when you create a new drawing from the Start page, select the template you created previously and all the CAD Standards you had set before will be included in the drawing.
SALMANUL FARIS
