imadHabash
en respuesta a: Anonymous
>>I design floor plans, so I need the page layout and page setup should be same each time I create or open AutoCAD. <<
then prepare your needed CAD info ( page setup,Layers,...) in an empty dwg then save it as .dwt CAD file ( Save As command) . then you can get it always from Ctrl+N shortcut .
also you can control it from OPTIONS command (see below image )
Imad Habash
