- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, I need some help.
I am using AutoCAD 2018 on Windows.
I design floor plans, so I need the page layout and page setup should be same each time I create or open AutoCAD.
all I need is the page setup , layout, Layer and other stuffs should be saved so that when I create new file I can use he old layers and page setup...
Please help!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>>I design floor plans, so I need the page layout and page setup should be same each time I create or open AutoCAD. <<
then prepare your needed CAD info ( page setup,Layers,...) in an empty dwg then save it as .dwt CAD file ( Save As command) . then you can get it always from Ctrl+N shortcut .
also you can control it from OPTIONS command (see below image )
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I would suggest you to start a new drawing, in that file create every CAD standard that you need in common for every newly created file. For example :
Create the Layers
Load the Linetypes
Do the Pagesetup
Create the layout sheet title block
Dimension style
Text style
Then Save-as the file as .dwt in the default template folder
Next time when you create a new drawing from the Start page, select the template you created previously and all the CAD Standards you had set before will be included in the drawing.
SALMANUL FARIS![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
