03-13-2019
03:20 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-13-2019
03:20 PM
Quick reply:
Scale the drawing, including dimension objects but not the text objects.
Take note of the scale factor you used to scale up or down the objects.
Now inverse this scale factor.
Adjust DIMLFAC to the inverse.
Command -DIMSTYLE "Apply" and select the scaled dimensions.
Notice the hyphen "-" at the beginning of the command name.
Example:
Scale the drawing 6 times.
Inverse is 1/6 or 0.16667.
Command DIMLFAC 0.16667
Command -DIMSTYLE "Apply"...
Example:
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.![]()
