en respuesta a: user181
Quick question: The shrub blocks you talked about are already blocks. When I go inside the blocks I see the hundreds of lines you talk about. How do you recommend I simplify this geometry? I don't think I was able to follow your previous recommendation...
@user181 wrote:
Hi @Anonymous ,  I have a couple suggestions.   In your drawing ground floor there are what look like shrubs on a layer named L_PLAN_TREES.  They are a bunch of individual lines and there are over 80,000 of them. I would suggest creating a block and inserting it multiple times. Try using the command -purge and purging regapps, empty text objects and zero-length geometry.  Also if the drawing saves slow try setting SAVEFIDELITY to 0 because you have annotative blocks in the drawings.
