03-13-2019
03:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-13-2019
03:20 AM
In that case you have few options, I'll briefly explain some below.
OPTION-1
Create a block with all the required elements including the dimensions, and scale the block.
OPTION-2
Scale the elements including the dimension and after that select all the dimensions and change the DIM SCALE LINEAR in the properties to match the scale factor used.
OPTION-3
Xref the elements you want to scale in to the drawing and scale the xref.
SALMANUL FARIS![]()
